Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
Paint for rims?
Old Aug 14, 2012 | 03:16 AM
kuma.lk's Avatar
Default Paint for rims?
I'm looking to paint my rims black. Any good suggestions? Looking for a flat black look. Not too glossy/shiny. Any suggestions? Like the rims I have and id rather not buy new ones, so I'd rather paint them.
Sent from my Autoguide iPhone app
Old Aug 14, 2012 | 08:36 AM
hilltoppersx's Avatar
Rust-Oleum High Performance Wheel, Flat Black: Automotive : Walmart.com
Old Aug 14, 2012 | 09:12 AM
JC Speiser's Avatar
That's exactly what I'm using on mine.
Here is the spare tire cover after 2 light coats:
Here is the spare tire I am about to paint:
Here is the center cap after masking and painting:
The paint is covering great - of course I am starting with a very clean base. PREP!
Old Aug 14, 2012 | 01:13 PM
JC Speiser's Avatar
I forgot the pic of the whole tire!
I hate it when my job gets in the way!
Old Aug 15, 2012 | 10:30 PM
yloDiscoII's Avatar
BINGO.
I painted mine satin black with that stuff 2.5 years ago. After many off road trips, and 2 Seattle winters, they are just now starting to get some flaking on around the edge of the rim, but considering I spent all of $12 for the paint, I'd say that's well worth it.
Old Aug 15, 2012 | 11:02 PM
nahtanoj's Avatar
i used charcoal grill paint on mine. looks good, no flaking yet. the paint was flat, but i put on semigloss clear coat so it is just a bit shiny.
Old Sep 11, 2012 | 09:52 AM
mattmo78's Avatar
I also read that John Deere makes a flat black paint that somebody used on their wheels. Supposed to work pretty good. It may be a little more heavy duty than the Wal-Mart spray paint? Not sure.
I'm looking into painting my wheels also. Maybe this Wal-Mart stuff is pretty good.
Old Nov 12, 2012 | 12:09 AM
CindyEvans's Avatar
I highly recommend doing this and for getting better results follow the instruction mentioned below:
1.Remove any dust or oils from the rim using alcohol.
2.After that before painting apply thin coats of primer on the rims, allowing each coat to dry for 30 minutes.
3. Then apply two or three thin coats of paint on the rims, with the interval of 30 minutes between each coat.
Old Feb 1, 2013 | 09:00 AM
Tartar8's Avatar
4th Gear
Those suggestions sound great. I just picked up a black '03 Disco SE with 63.5K miles on Tuesday, had the windows limo tinted yesterday, and will be painting the rims black in the next few weeks. I love that look and these suggestions should help out a ton.
Question: when you guys have painted your wheels, have you put your vehicles on blocks and took all the wheels off at once, or did you work on one wheel at a time?
Old Feb 1, 2013 | 09:50 AM
blamo's Avatar
I used a green scotthbrite to scuff & self priming epoxypaint from vht .
