Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
Tire size question
Old Oct 1, 2012 | 07:46 AM
cavdiver2's Avatar
Default Tire size question
Sorry I'm sure this has been asked a lot but I hope someone will still help me out. I have a 2002 Disco II SE7 and I want to put the largest tires on my 18" rims that I can. I am still at stock height for now. I am looking for a tall tire not wide. So any suggestions on size would be great, I'll worry about brand as I shop around. Thanks for help!!
Michael
Old Oct 2, 2012 | 08:53 AM
First with a stock suspension you really can only go up one size and sometimes they will even rub.
To go larger, you must start with a lift then add tires, remember the larger the tire the more torques, power you will loose plus about 1.5 MPG. Also the larger the tire the wider they get so I would switch to 16" wheels where you have a much larger selection of tires and sizes and then buy a 235/80/16 or similiar size.
MountainOx
Sep 22, 2009 12:32 AM
sixthflick
May 24, 2009 12:11 AM
flyplanes5
Nov 2, 2008 08:30 PM
jwood700
Oct 28, 2008 05:53 PM
ajh
Oct 23, 2007 10:13 AM
