Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
installing an aftermarket deck
Old May 8, 2007 | 07:29 PM
andrewkim06's Avatar
3rd Gear
Default installing an aftermarket deck
99 DiscoII, alpine deck, harman-kardon.
I was installing my kenwood deck,
and I noticed 2 antenna connector...?
I hooked the bigger one to my deck, but what's the small one for?
Old May 30, 2007 | 09:40 AM
Aquaholic's Avatar
Default RE: installing an aftermarket deck
I think it's for AM
Old Aug 3, 2007 | 01:24 AM
DiscoveyII Driver's Avatar
lol you have a weather band with land rover witch does not come with other cars that is what it is mainly for the weather band. and to tell you the truth put the stock back in it's like take the bose souround sound out of the home and hooking up a pyle lol
Old Oct 24, 2007 | 01:12 AM
N.Franklin's Avatar
According to the Rave CD? I think is where I read it, the left antenna is your main antenna and your right antenna had something to do with picking up the signal in urban areas, but both were for FM. I plugged into the left one, no problems.
Old Oct 28, 2007 | 09:45 PM
Rioja Red's Avatar
It’s called a diversity reception antenna. They are both the same. I am not a radio engineer by any stretch. They are amplified antennas used conjunctively with some form of gain matching in the receiver section. There are three different ways to do this so I have been led to believe.
I am facing the same situation with my 99 RR 4.0S. Right now I have only one hooked up. Works great. Use either one doesn’t matter however I think you may get a small amount of range loss. It won't harm anything to use a Y adaptor to connect them both but I've read that they may somehow cancel themselves out, don't really know but I will soon.
I have ordered two DIN to ISO antenna lead adaptors and a diversity antenna adaptor for some late 90's model Nissan. After I get this all waded up and plugged in behind the radio I'll let you know if any smoke came out from anything
toad2
Jul 1, 2012 06:56 PM
patsilva
Jan 3, 2012 02:07 AM
JayJaeMc
Feb 16, 2010 11:36 PM
Sircedric88
Jun 1, 2009 06:34 PM
WGM
Apr 14, 2007 10:32 AM
