Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Brand Reviews > Audio/Visual Electronics
Register Forgot Password?
Old 08-21-2011, 12:59 PM
collin Barrows's Avatar
Senior Member
Collin Oscar Barrows
Question D1 audio upgrade, a might stumped
Hello, as you might know from my previous thread, My Brother (electrical engineer for Lockheed Martin) and I where in the midst of upgrading my music enjoying experience. In doing so, we ran into trouble with the Amp connecting with the RCA cables, if you touch the white plug to the outside of RCA ring it works fine and dandy, but when you plug it in to the RCA port it drops the power output to 1/4 of what it should be. Any ideas? Sorry if I have misspelled words or run on sentences...
Thanks
Collin
__________________
Our fleet:
1960 Morris Minor Pick up (right hand drive)
The Tartus: 95 Disco with a full wilderness roof rack, 4 PIA lights on the rack, brush guard, with 2 fog lights, rear tail light guard, 2in Todco lift, Rhino Painted the cargo area, 5 Pro Comp 33in Mud Terrain Tires %75 tread, diff skid plate, and I'm only 18 ....
Bipolar: 2000 p38 Range Rover Brush guard, rear lamp guard, new grill, coil suspension.
Old 08-21-2011, 05:57 PM
Senior Member
tencreds10
Is that the converter they sell at best buy?
If so, Maybe its not working like it should?
__________________
Discovery I 1995 with 178,XXX
New oil pump, timing chain, fan clutch and radiator... NO LEAKS! Knock on wood...
Old 08-21-2011, 09:18 PM
Senior Member
Sounds like a ground loop to me. Brother will know what that is.
__________________
Old 08-21-2011, 10:31 PM
Senior Member
I will take a look at that in the AM, hopefully I can wire the amp up before school tomorrow (with out doing something stupid), oh one more thing, while hooking up the amp/sub i ran across a solenoid. It trigures when you hit the brake, i thinks its red. I'll snap a couple pics and throw them up tomrrow morning.
Thanks for the help!
__________________
Our fleet:
Old 08-21-2011, 11:04 PM
Senior Member
tencreds10
Where you go to school?
__________________
Old 08-21-2011, 11:10 PM
Senior Member
from Rave electrical troubleshooting guide:
When the gear selector is in the park position, the
solenoid inside the Transmission Range Selector
Switch (Z110) is de–energised and prevents the
selector from being moved into another gear. To free
the selector, the Ignition Switch (X134) must be in
position II and the brake pedal must be depressed.
When this occurs, voltage from Fuse F1 is applied to
the Transmission Range Selector through the closed
Stop Lamp Switch (X168). The solenoid inside the
Transmission Range Selector Switch is grounded at
E201 through the selector switch, the KS wire and
the B wire. The solenoid now energises, freeing the
selector
__________________
Old 08-22-2011, 04:24 AM
Senior Member
oh i forgot, my amp is made by kenwood, the model is KAC-646
I'm a senior at Jefferson High School, Jefferson GA...
__________________
Our fleet:
Old 08-22-2011, 12:38 PM
wheelgarage's Avatar
Senior Member
Are you using the Metra harness to hook up the new deck by any chance? Curious to see if this will be an issue with me also.
__________________
1996 Discovery SE7 - 5-Speed
Fully protected by Redline Oil / Lucas Grease
Terrafirma: MED Duty Lift Kit, Steering Damper, Castor Correct Radius Arms, Rear Cranked Radius Arms, Shock Turret Rings, HD Track Rods, Extended Stainless Brake Lines
Tyler-Engineering Steering Damper brackets; Polybush Orange Kit; OEM Swaybar Bushings; Adventure Roof Rack; Hella 500's; ARB Front Bumper
265/75/16 Cooper Discoverer STT; Terrafirma 16 x 7 TF100 Alloy Wheels - Anthracite
Work in progress......
Old 08-22-2011, 08:58 PM
Senior Member
I'm kinda making my own wiring harness... I have my remote wire going to my driver speaker. I grounded the negative cable to driver seat, and the amp is located under my seat.
Thanks SB, a I'll take a look tomorrow
__________________
Our fleet:
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
