If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
If you go to http://www.tss-radio.com/products/land-rover-kenwood-sirius-tuner-package they sell a package that allows you to use your stock stereo to receive Sirius radio.
The package comes with a Kenwood Sirius receiver, antenna, cable and Pie interface adaptor, the best part is you don’t even have to remove you stock stereo to hook it up.
Plug one end of their cable into the Kenwood receiver, connect the Pie interface adaptor to the other end, and now plug the interface cable into the 10-pin connector under the passenger seat for the CD player (no power necessary). Throw the antenna on the roof and call Sirius to activate (or you can activate on line).
The Sirius programing will show on your stock stereo, you can use the stock steering wheel controls for volume and channel changes. Oh and it you want to keep your CD or add an I-pod there is a slave port on the receiver that you can hook you CD back up too. The Kenwood receiver also has a two female RCA jacks. The Pie interface cable and comes with a second cable that has two male RCA connector and a male 3.5 mm ?? Plug; which I assume plugs into an mp3 player.
So you don’t need and aftermarket stereo that just doesn’t look right or has the wrong colored lights, no special adaptors to get your steering wheel controls to interface and other than the antenna you can’t tell it’s there. I left mine under the passenger seat were the CD player would be, but the cable is about 8 feet long so you could put it just about any were in the truck that you wanted.
Now it does not give you all the functions of a new Sirius stereo, like logging artists, playback & repeat. It probably does more but I would have to read the direction and you know that any going to happen.
What is does do is allow you to have satellite radio using all the stock Harmon Kardon equipment and you can be up and running in 5 minute or less.
Best of all it only costs $119.99 OR $89.99 If you’re a new subscriber, I feel like I got ripped off I have a life time subscription and some one new can buy the equipment cheaper than me. Oh well; at least I get my satellite radio & up to date traffic reports back, terrestrial radio sucks.
__________________
00 Disco 4.0 80k miles SLS, ACE, 7 passenger 255x65x18: Repairs since 02/11 new intake, valve cover, head, timing cover, waterpump & oil sump gaskets, new timing chain & gears, water pump, t-stat, hoses, belt, new front drive shaft, Akebono pads, D&S rotors, SS brake lines, clutch fan, HMS completed.
90 RRC County
67 mustang GTA
73 Jeepster Commandos
69 Honda SOHC
71 HD FX
72 BSA Lightning
73 Honda SOHC
78 Honda SS
87 HD FLTP
2004 HD SE 103
He who dies with the most toys, WINS
