4.6 engine build
#21
well, I was going through my big box of bits. took a shopping list of stuff I do not have, yet.
cam bearing is on the list. ab has a closeout on unfinished..........but then I saw that they have a finished set. how does that work? what gives? are they saying that it is pre sized and a universal, with in spec, option?
#22
#23
can't say for sure about the cam bearings, i have alway just have the machine shop replace them; after hot tanking they are junk anyway. what did you have chevy valves and beehive spring installed in the heads? i assume you are going to gasket match the heads and intake, if so make sure you have a couple gaskets you dont want to open them to only fit one set.
#24
#25
no beehive. crower tung. dual springs were used. the numbers worked great. Valve Springs . machine shop did a great job fitting the larger diameters.
cam is crower 53231
yes I will gasket match...would hate to defeat the matching that was done.
#26
#27
#28
#29
#30
