Defender Talk about the Land Rover Defender within.
Electrical problem: don't know what else to try
Old Jul 17, 2010 | 08:34 AM
farmer2010's Avatar
Default Electrical problem: don't know what else to try
Hi,
I recently had a small accident with my Defender 110 Td5 of 1999 that damaged all the rear right lights.
I could fix all except the turn signal. The shock caused a short circuit in that lamp connector that made the alarm system go crazy and inmobilized the engine shortly after the accident. I eliminated the shortcircuit, replaced some fuses and solved the alarm/engine problem.
BUT I realized that now none of the turn signals work (not only the rear right one). Moreover, the fuel gauge and the coolant temperature gauge don't work. All these elements have in common the white-green cable.
I have checked all the fuses and they are ok. Now the cables going to the rear right turn light (white-green and black) are not connected to anything as I haven't put the new lamp yet.
I use the truck everyday and I cannot drive on main roads without side lights, so I would really appreciate your help.
calebbo
Oct 12, 2011 09:54 PM
Gr8lite
Aug 12, 2010 10:36 AM
tornado_735
Apr 18, 2009 06:07 PM
97DISCOIDAHO
Aug 30, 2006 02:40 AM
