Bent Sway Bar Bracket?
After some wheeling the other week, I noticed some clunking noises coming from the rear of the truck.
I discovered the following (see pictures). The left rear sway back bracket bent upwards, coming in close contact with the fuel tank and mangled bushings. Is a bent bracket a fairly common occurrence after moderate to substantial articulation? I plan on just removing the rear sway bar assembly at this point.
You just answered your own question, you didn't plan far enough ahead.
The only thing the sway bars do mechanically is touch both sides of the axle with a double ball-jointed looking thingy. The tin foil like structure attached to the frame is simply to hold the sway bar from spinning away like a frisbee after a roll-over. When I attempt a somewhat high-speed 14.5 mph corner my just filled tank registers empty and I can hear the float hi-five the fuel tank bottom.
Speed racer
11-11-2009 09:44 AM
Mountain_Rover
06-05-2009 10:45 PM
