Bent Sway Bar Bracket?
Old Mar 27, 2015 | 07:01 PM
TDRover's Avatar
Default Bent Sway Bar Bracket?
After some wheeling the other week, I noticed some clunking noises coming from the rear of the truck.
I discovered the following (see pictures). The left rear sway back bracket bent upwards, coming in close contact with the fuel tank and mangled bushings. Is a bent bracket a fairly common occurrence after moderate to substantial articulation? I plan on just removing the rear sway bar assembly at this point.
Old Mar 27, 2015 | 08:02 PM
TOM R's Avatar
Those sway bar end links are supposed to face down iirc
If you have a lift ditch the sway bars, they do more harm then good
Old Mar 27, 2015 | 08:03 PM
ihscouts's Avatar
You just answered your own question, you didn't plan far enough ahead.
The only thing the sway bars do mechanically is touch both sides of the axle with a double ball-jointed looking thingy. The tin foil like structure attached to the frame is simply to hold the sway bar from spinning away like a frisbee after a roll-over. When I attempt a somewhat high-speed 14.5 mph corner my just filled tank registers empty and I can hear the float hi-five the fuel tank bottom.
Old Mar 27, 2015 | 08:11 PM
OverRover's Avatar
Your right Tom the link ends are pointed in the wrong direction.
Old Mar 27, 2015 | 09:04 PM
fishEH's Avatar
I want to do something like this on my '95. Extend the links so it makes the front work harder.
deer4011
Jan 12, 2021 07:10 AM
Speed racer
Nov 11, 2009 09:44 AM
Mountain_Rover
Jun 5, 2009 10:45 PM
sailorcolin
Feb 22, 2008 10:46 PM
BradHall
Nov 11, 2007 04:57 PM
