Cotter and other 'pull' pins
on
First straighten keeper end(s) as much as you can. Fit steel (reasonably hard steel) ice pick or awl into head and gently pry against nut/metal pin is through. Once far enough out to grab with pliers go for it. Get a better grip using wire dams to make indentation with/for pulling.
If this doesn't work tap out from keeper end.
bobbydave
12-08-2007 12:49 PM
