Wheel Bearings and Swivel Pins
Old Nov 18, 2012 | 01:47 PM
JPSpen's Avatar
Default Wheel Bearings and Swivel Pins
Ok.. Finally got the shop cleaned out and got the Discette up on some stands... I have no perceptable play side to side and enough to make a tiny clunk when I push and pull on the top of the wheel..
Swivel Pins... How much play if any is acceptable ?????...
I know I'll probably need to rebuild them. But today I'm thinking about just going in and taking out a shim to tighten them up...I don't have set of fish scales or the "special tool #xxxxx but I figure if I get them with some fairly good drag that's gotta be better than they are now..
I think my wobble issue is now mostly toe in.. It's nearly 1/2" instead of 2mm....
Gotta go get a new tie rod end puller and fix that...I broke mine trying to get the steering arm off the box...
So.. How much play is acceptable ? Any ?
Thanks
John
aarongregor
Sep 7, 2018 12:37 PM
RichardBoutwell
Nov 13, 2013 02:32 PM
Rover Chris
Dec 5, 2010 03:46 PM
kenk
Sep 21, 2010 08:45 PM
kenk
Feb 9, 2010 11:43 AM
