D1 02 sensor cost savings.
Old Oct 30, 2010 | 06:49 PM
Default D1 02 sensor cost savings.
I found out today that you can in fact use the less expensive older 02's on the late model D1 with the Advanced Evap. system. Turns out they both use the same 02 body, the only difference is the plug, which if you are very careful, you can remove the old plug, don't cut the wires, use a minature screw driver, and install it on the less expensive 02's and you are set.
To verify this, look at the model number on both 02 bodies, they are both the same.
Old Oct 31, 2010 | 08:42 AM
antichrist's Avatar
I haven't seen DII sensors for less that $53 which is what you can get the D1 w/AEL sensors, which have the correct connectors.
SuperiorCarCare
Detailing
Dec 6, 2013 05:36 PM
SuperiorCarCare
Detailing
Dec 2, 2013 07:51 AM
arnottdoug
Aug 13, 2012 09:14 AM
MARSRover
Jul 2, 2012 06:16 PM
AtlanticBritish
Member Group And Special Buys
Jan 20, 2012 11:54 AM
