O2 or MAF? P1179
Old May 31, 2013 | 03:12 PM
jdblep's Avatar
Default O2 or MAF? P1179
Got a CEL today P1179. Had just replaced fuel pump/filter, plugs/wires, air filter, and oil. Has been having rough hot starts for some time. Also noticed that the o2 sensors were showing a lean condition. Should i focus on the MAF/intake cleaning, or replace the o2 sensors up/down? Thanks in advance, this forum rocks!
Attached Thumbnails O2 or MAF? P1179-photo-1.jpg   O2 or MAF? P1179-photo-2.jpg   O2 or MAF? P1179-photo-3.jpg   O2 or MAF? P1179-photo-4.jpg   O2 or MAF? P1179-photo-5.jpg
Old May 31, 2013 | 04:04 PM
MAF cleaning when stone cold with made for MAF spray. Air filter not dirty.
Old Jul 30, 2013 | 08:51 AM
jdblep's Avatar
Still having issues with codes (particularity P1179 and P0451). I did a complete intake/MAF cleaning, but still throwing codes about once a week. One thing I did notice is that the O2 sensors are vastly different between bank 1 and 2. Bank 2 seems to run around double what bank 1 is showing. Should i focus on replacing the upstream sensors, or is there something that would cause this? Checked fuel pressure (already replaced pump and filter) and has a constant 32psi. Also what should i be looking at for the P0451 (purge valve?).
Thanks!
Old Jul 31, 2013 | 07:37 AM
TOM R's Avatar
If you can see live data stream the upstream o2should fluctuate the numbers rapidly if not I would say replace, hard hot start could be fuel temp sendor
Old Jul 31, 2013 | 05:35 PM
jastutte's Avatar
you may also want to check for a vacuum leak if the O2 sensors check out okay.
Spencerfitch
Feb 6, 2011 01:07 PM
RoverRover1
Apr 26, 2009 10:48 AM
willlane
Jul 13, 2008 10:28 PM
rcendo
Jan 30, 2008 06:56 PM
Craig
Jul 6, 2007 05:00 PM
