Stop Light Switch (code 2-6)-abs light
Old Nov 26, 2010 | 02:59 PM
tibyABv6's Avatar
Default Stop Light Switch (code 2-6)-abs light
As i am working on my brakes i decided to investigate my ABS light using paper clip/light code reading.
I am getting only 2-6 (blink, blink......blink,blnk,blnk,blnk,blnk,blnk) which means brake light switch/stop light switch is faulty.
Does brake light switch affects ABS? My brake light come on, and i can shift out of park - does it not mean that brake light switch is functioning?
I am wondering if problem is somewhere else...do not want to shed out $20 to find out that brake light switch is not it.
Old Nov 26, 2010 | 04:30 PM
If your brake lights are working then the brake light switch is fine.
Old Nov 26, 2010 | 09:29 PM
tibyABv6's Avatar
The only way i can think of brake light switch causing problem is, if it is partially broken ... I am not good at electrical diagrams, but it seams that it has two "switches" inside that one switch. Diagram has no clear annotations, so i do know know which loop is used for what. Does any one knows why is there a 2 levels of brake travel [1] and [2] ....depressed and further depressed.... (when i hit brakes really fast and deep...on snowy road...abs would come on for a sec and then would stop functioning)
Or maybe problem is in ABS control module.
abs-rower.jpg?t=1290827608
Old Nov 27, 2010 | 03:38 PM
Well the only way to rule out the brake light switch is to replace it.
Old Nov 28, 2010 | 12:51 PM
tibyABv6's Avatar
yes...once i will be done with brakes (rebuilding calipers - some of the pistons are frozen) i will clear code and see if it stays off, if not - will buy the switch
Old Nov 28, 2010 | 02:23 PM
Rovin4life's Avatar
how about seating and tapping the abs sensors and making sure the air gap isn't bad by having a loose wheel bearing?
Old Nov 29, 2010 | 08:09 PM
tibyABv6's Avatar
I took each sensor out last year cleaned it and taped them back in.
As far as wheel bearing - i did not feel anything play in it when i removed hub, while replacing rotors.
Old Dec 17, 2011 | 01:10 PM
NorCal's Avatar
3rd Gear
Question What was brake stop light solution?
Having the same issue: brake lights stay on, even when lights all on off, 96 Disco does start - what was the solution?
thearmlesswonder
Dec 10, 2014 10:27 AM
CapeRover
May 3, 2013 04:35 PM
s10lowrider1994
Sep 19, 2011 04:23 AM
