Master Cylinder Rebuild kit
Old Dec 12, 2011 | 09:29 AM
kamileon's Avatar
Default Master Cylinder Rebuild kit
So I have been out of the country for a while and just got back this weekend. Anyway, my D1 has been sitting for the 8 months or so I have been gone. Was going through her yesterday to get her running again. I noticed the brake reservoir was close to empty, so I filled her up. Got everything done and took her for a quick drive around the neighborhood only to find the brakes not working. Ended having to use the e-brake to stop and get home.
When I got back in the garage I found the brake reservoir again empty. So I filled it up again and had the wife sit in the car and press the brake pedal. While doing so I noticed brake fluid running down the side and back of the master cylinder. So I pulled it off and found the rubber boots where the reservoir connects to the master cylinder had rotted away and was allowing the brake fluid to run out. So I searched around and called a few part stores in my area looking for the boots. only one place carried them and it was as a rebuild kit, $300.00. He also told me I could buy a new master cylinder with the new boots for the same price. Same thing on all the rover parts web pages. Only thing have not done yet is call the dealership to see if they carry the boots.
So my question is does anyone know where to get just the boots? Or if maybe another vehicle has this part in common or one that I could use from a different vehicle. I really dont want to pay $300 just for two rubber boots.
EDIT: Parts(boots) found, they are an Audi part and I purchased them at my local Audi dealership. Part numbers are 893611817B & 4AO611817A, they ran me about $40.
Old Dec 12, 2011 | 10:03 AM
Sam95disco's Avatar
this happened to me, i had to order the kit but all i needed was the rubber bushings i couldnt find them alone kit cost 56
edit just saw you have a 98, i guess they use the same one
http://www.britishpacific.com/produc...+Kit&year=1998
Old Dec 12, 2011 | 10:04 AM
Go to Atlantic British, they have the original factory rebuild kit at a great price.
Old Dec 12, 2011 | 10:13 AM
Sam95disco's Avatar
hey mike, do all 95s have the brake sensor(wear indicator). just changed the pads, ones i got have the wire, but unable to find it on my truck where it would connect to.
Old Dec 12, 2011 | 02:17 PM
kamileon's Avatar
Ok so I found just the boots by themselves. I called my local Rover stealership and the parts guy said they do sell just the boots, however they are an Audi part. So I called the Audi dealership and they had them in stock. Funny part is the guy at the parts counter at Audi asked me what year my Rover was, he said they sell about two or three of these a year and always to Rover owners. Funny how that works. Anyway the part numbers are 893611817B & 4AO611817A, they ran me about $40. I will also edit the op to reflect the part numbers. Thanks for everyones help.
Old Dec 12, 2011 | 02:36 PM
Sam95disco's Avatar
damn dealer here told me they dont sell them alone got to get the whole cylinder . for 40, well i got the whole rebulit kit for 56. oh well.
Old Dec 12, 2011 | 03:44 PM
jafir's Avatar
They are probably Range Rover pads.
Old Dec 13, 2011 | 09:58 PM
Sam95disco's Avatar
So its no biggy if I just cut the wire?
Old Dec 15, 2011 | 10:21 PM
kamileon's Avatar
I cut the ones on mine and havent had any problems. But not sure if it was a good thing to do or not.
Old Dec 15, 2011 | 11:15 PM
LeakyDisco's Avatar
I recently did my 97 SD and I cut the wires. The old pads had them cut as well, and I didn't see anyplace to hook them up; didn't see anything in the RAVE diagram either.
Chrisinhouston
Jan 6, 2015 07:00 AM
CANAMDiscovery
Jan 16, 2013 07:54 AM
99discoverysc
Nov 30, 2009 02:54 PM
mburnett
Sep 27, 2009 02:33 PM
PITTDISCO
Feb 22, 2008 09:51 PM
