Front drive-shaft spline
So how important is the plastic coating on the spline shaft?
On the male spline, the coating is gone on the major diameter (peaks) but is still in the minor diameter (valleys).
Will a D2/DC shaft work on an unlifted D1? The price at Lucky8 is not bad on the D2 shaft compared to the D1 shaft they have listed.
Did the two halves of the driveshaft separate at any point? I ask because the ujoints in the stock D1 shaft are out of phase, meaning the yokes don't line up perfectly like other shafts.
If the shaft was apart at one point and not aligned properly on reassembly that could be your vibration.
Yes, I separated the two halves of the shaft. I marked/scribed before disassembly. That is when I noticed that the plastic coating, Rislan, was worn away.
The vibration in the steering wheel is now gone since I greased the crap out of the rear universals. They need replacing and I'm just waiting for the weekend.
It is not the death wobble. Had it when I first got it but it went away after doing several lock to lock figure 8's in my yard.
I just don't like the flex at the spline.
DiscoJon
07-14-2019 01:51 PM
TripleThreat
04-12-2011 08:58 AM
