lookin at discos
Old Dec 13, 2011 | 09:49 PM
MountainOx's Avatar
Default lookin at discos
i'm not a troll
whats a better rig for the off road use?
D1 or D2
dose a d1 have traction control?
dose it have a locking center diff?
or should i buy another RRC?
discos are more available in my area right now. decent trucks from 1900-5500, year from 1992-2002 milages from 84xxx - 180xxx dunno which Disco to grab please enlighten me . i hate my jeep i replaced my RRC with !
Old Dec 13, 2011 | 10:03 PM
collin Barrows's Avatar
D1 are cheaper, have CDL, no TC, easy to find parts at bone yards.
D2 early modles have CDl but I think they stopped in 03 (I'm not 100% sure), but they do have TC.
Old Dec 13, 2011 | 10:07 PM
honda50r's Avatar
I'd go D1. Less problems along with a solid CDL and cheaper replacement parts, not to mention there is a bigger availability of their parts.
But, this is coming from a D1 guy. I guess it's whatever you're looking for
Old Dec 13, 2011 | 10:21 PM
fishEH's Avatar
A D1 is going to be just like your RRC. CDL and no TC. All D2's will have TC, only some will have CDL. D2's lift better, D1's have less stuff to go wrong.
Old Dec 13, 2011 | 11:41 PM
MountainOx's Avatar
i'm of the belife of less is more. looks like year wise mainly d1's are available. i dont see why not a d1.
can any one explain the trim to me se sd ? or what they happen to be. what model wont have a sun roof? its not a needed option, also any have a tow package that's worth having or?
how about tire size for stock gearing? i was on 32's was ok on my rrc. could i get away with a 34? and lift? want to do this proper.
http://seattle.craigslist.org/oly/cto/2743875294.html\
Land Rover Discovery 98'
Old Dec 14, 2011 | 09:13 AM
WaltNYC's Avatar
SD was cloth seats and sunroofs were optional. SE was 'pleather' and had two sunroofs. The sunroofs can be problematic and unless you are buying a real 'cherry' it is probably less hassle to find a truck without the sunroofs.
All the trucks have a tow hitch receiver.
There is a sticky at the top of this section about what to look for in D1's. The biggest mechanical issues are fuel pump failure and head gasket failure. Though there are plenty more to occupy your time.
Old Dec 14, 2011 | 10:08 AM
LeakyDisco's Avatar
I'm not 100% certain, but the trim options may have improved in the latter half of D1 production. For example, I have a 97 SD with leather seats. I do not have sunroofs, nor do I have fog lights, as much wood trim, or heated seats that I believe the fancier models had. Seems to me like 95 and earlier had cloth on bases models, where 96 and later switched to standard leather. It could also be that the original owner of my SD added the leather as an option, I dunno.
An SE7 is going to have the child-sized jump seats in the back unless the PO removed them. Keep in mind that all D1s have the mounting brackets for the jump seats, so you can (like I did) install them later with minimal effort.
There is also an LSE model I have seen which (I think) has chrome bumpers or chrome adornments of some sort. Personally I don't care for that look, but that wouldn't stop me from buying one if it was a solid truck.
Old Dec 14, 2011 | 10:18 AM
IMHO the D1 cooling system is superior, even though they use the same water pump. Big copper and brass radiator, more rows that the D2. Oil cooler, not always on a D2. More options for cooling fans, and thermostat is built for a Buick, not a heart transplant. You can run any temp you want (160, 180, 195) vs one choice for a D2. When you are moving slow in low range, working the engine, that cooling fan and jumbo radiator play a bigger part that hauling groceries back from the store.
Old Dec 14, 2011 | 08:36 PM
MountainOx's Avatar
Thanks for the input gents. I will hit up the thread about what to look for here in a bit and post a few more questions if I have some.
Ecoe Blazin
Jan 17, 2019 09:31 PM
MountainOx
Sep 25, 2009 07:59 PM
Titanman
Jan 5, 2009 12:42 PM
RobinHood
Apr 18, 2008 01:40 AM
Swoll50
Mar 1, 2005 12:54 AM
