Non-AC Serpentine Belt
Old May 15, 2012 | 02:56 PM
EricTyrrell's Avatar
Default Non-AC Serpentine Belt
Those who wish to remove the air conditioning system from a 4.0 V8 Discovery will need a non-AC serpentine belt. This can be difficult to find so I've compiled my research below.
The part # is ERR6191. It's manufactured by Dayco with the part # 7PK1853 and is available from Rock Auto for $20.
Dayco 7PK1855 will also work. Cross reference: 07-09 BMW 335i, 135i
Model # means 7(# of ribs)P(Poly-V)K(?)1853(length in mm)
EDIT: The D1 tensioner must also be replaced with a D2 tensioner.
Old May 15, 2012 | 02:59 PM
While I'm not ready to give up AC just yet in my opposite corner of the country, what kind of MPG change did you see?
Old May 16, 2012 | 10:45 AM
Haven't done it yet buzz, just sharing the research so far.
Old May 16, 2012 | 11:29 AM
ValveCoverGasket's Avatar
Originally Posted by EricTyrrell
Haven't done it yet buzz, just sharing the research so far. Another thing to consider is that the AC is used for defrost.
thats why i think mine is staying in my truck... need it to defrost after snowboarding.
Old May 16, 2012 | 04:05 PM
Yes, but you are correct, this is valuable info to those that might find themselves stranded with siezed AC clutch. We should have a sticky with various belts like this, and the ACS bypass for the D2, etc. Good work.
Old May 16, 2012 | 06:22 PM
The a/c does not come on when you turn the defroster on in the DI, you must turn the a/c on.
Old Jun 29, 2012 | 11:14 PM
AZlandy's Avatar
so if i go to autozone or o reilly and ask for a belt for a 07-09 bmw 335i i can bypass the ac?
Old Jun 30, 2012 | 10:54 AM
AZlandy's Avatar
i need help lol i checked the belt and its about to go pretty soon its starting to come apart . can someone tell me if the part numbers at the top of the page work at napa, oreilly ,or autozone . i want to get a new belt so i can bypass the ac because it needs to be fixed anyway.
Old Jun 30, 2012 | 11:06 AM
Bkreutz's Avatar
All parts places have cross over charts for any belt number so pick which one you want to use and give them the Dayco number.
Old Jun 30, 2012 | 12:55 PM
Hi, AZLandy. I was failry confident the belt was all that was required, but a dweb member suggested there was more to it. I never followed up with him though. I'm going to find out what else is involved.
