quick stereo question
Old Jan 10, 2012 | 03:50 PM
JoeManly's Avatar
It worked for me, but my setup was a little different (bypassed the amp). It's worth a try, if it doesn't work your only out a few dollars and minutes. Good luck.
Old Jan 10, 2012 | 04:56 PM
turf63's Avatar
I bought a ten dollar small one that I tried up at the head unit and a 12$ cylindrical one that I tried at the head unit at the amp. To no avail no worries. I'm returning them now. It only took a few minutes. Sigh. Thanks for the input dude.
Old Jan 10, 2012 | 04:58 PM
turf63's Avatar
Originally Posted by ValveCoverGasket
please keep an eye on that wire - especially where its crimped into any connections - solid core wiring (along with wiring nuts!) is not meant for applications where vibration exists.... like your car.
if you have an extra couple minutes, i would redo that with some stranded wire.
Will do. I had just run out of stranded. I'll grab some soon
Old Jan 16, 2012 | 01:48 AM
JoeManly's Avatar
Here's a good article I found on eliminating noise. ( How To - Car Stereo - In Pursuit of a Noise-Free System: The Ten Commandments of Noise Prevention) I re-read your post and noticed that the noise was coming only from one speaker. I would check that the wiring to that speaker is running by itself and not next to any other wires, like a power supply wire, that could cause the interference.
Old Jan 16, 2012 | 07:39 PM
turf63's Avatar
Joe, i appreciate the follow up. I'll def read the article. I'm more inclined to think that the reason im getting the interference on that speaker only however is because it's the only speaker after the amp. Although the subwoofer is hooked to the amp too, i think i just can't hear the whine from the sub because the pitch is to low. I'm more convinced it's related to the amp/rca cable/ground situation. Howver, having said that i was careful to run my rca's and power supply on opposite sides of the truck, that didnt seem to be the issue. I'm close to going down the street to an indy shop and asking if they wouldnt mind chasing the noise for me, im curious how much it could cost. I'm sure theyd take a look at my stuff and recommend a total re-wire, haha
amdhotprocessor
Dec 28, 2012 10:12 AM
lilherc
Dec 14, 2012 12:29 PM
icyhot201
Aug 16, 2010 07:24 PM
endneu913
Nov 3, 2007 03:46 PM
suntattoo80
Feb 14, 2007 09:25 PM
