So what did you do to your Disco today?
Old May 16, 2012 | 08:45 AM
  #321
slanginsanjuan's Avatar
Originally Posted by llesra
today i had my worn out bushings pressed out, had the radius arms sand blasted, powder coated silver, installed ironman bushings, and reinstalled the radius arms. busy day for the arms haha
nice.
Old May 16, 2012 | 09:00 AM
  #322
fishEH's Avatar
Speaking of radius arms...... I sold three sets of stock radius arms to RoverTym for $225.
Old May 16, 2012 | 10:01 AM
  #323
Jake1996D1's Avatar
How much did it cost to ship them?
Old May 16, 2012 | 10:11 AM
  #324
fishEH's Avatar
Bill sent me prepaid UPS Call Tags. So didn't cost me a thing. Well, I did buy a roll of that shrink wrap stuff so I'm $5 into it I guess.
Old May 16, 2012 | 11:43 AM
  #325
fishEH's Avatar
And I just sold 4 Disco catalytic converters for $340.
Old May 16, 2012 | 06:17 PM
  #326
Sam95disco's Avatar
Took my heads to the shop, $140 for valve job and $45 for resurface(each head). Dropped off the rad at a rad shop, $75 to rod-out and clean out grime. Alternator was bad, got a rebuilt one coming(lifetime warranty). I should have everything by Friday. Total cost for parts $645. I still need another cond fan motor, hit Sam's club for the rotella oil and k&n air filter.
Old May 16, 2012 | 06:30 PM
  #327
llesra's Avatar
so do you just email em and say you've got a pair of stock radius arms for sale? i'd take $75 for mine!
Old May 16, 2012 | 09:01 PM
  #328
RGV97's Avatar
8th Gear
was in process of changing window regulator when transmission line went out on my way home....
Old May 17, 2012 | 07:50 AM
  #329
DiscoJag's Avatar
I spent a weekend working on my window lift ECU. The biggest problem was getting the top connector plug off the circuit board. I read that this is a common problem. I finally got it off with a pair of pliers and a lot of force. Before I got it out I noticed that none of my windows were working - instead of just the rear ones. While getting the top connector off I had wiggled and pulled on the connector so much that I broke the solder joints for the top plug right where the wires go throught the board. So after resoldering those and attempting to solder the dry joint in the middle I still had rear window problems, so I did the jumper on the rear window connector and now all is well. I also got a used window ECU off fleaBay for when/if this fix gives out. Painful, but a good learning experience.
Old May 17, 2012 | 08:01 AM
  #330
i fixed mine this past weekend as well. i chose to bypass it with a single wire. thanks xceller. i did pretty much all 8 windows.
