Tiny leak in top of front cover.
Old Feb 25, 2012 | 06:42 PM
  #21
AutoZone, quick lubes, etc. will take the old coolant.
It can be mixed with used oil for recycling.
There is no drain on the radiator, if you are replacing the bottom hose you can drill a hole in it.
If you ever have your radiator rebuild you can have them add a petcock.
Old Feb 25, 2012 | 06:46 PM
  #22
adigerol77's Avatar
My local AZ wouldn't let me dump my coolant in with the oil.
Old Feb 25, 2012 | 06:47 PM
  #23
Higgs Boson's Avatar
In the future you might want to obtain a primer bulb type siphon setup. I usually drain the reservoir with it first, then remove the bleed plug on the top of the radiator and push the hose all the way to the bottom of the side tank to siphon out as much as possible. You'll still lose a couple ounces of coolant when you pull the lower hose off the radiator, but nothing like the epic gyser when trying to drain the system by pulling the lower hose off.
Old Feb 25, 2012 | 07:07 PM
  #24
LeakyDisco's Avatar
I'll keep these tricks in mind when I have to drain it again someday.
My local O'Reily's only takes hydraulic fluids (oil, ps, atf, etc.), but there are other places nearby that will probably take it. I might actually be able to take it to a local transfer station that accepts some chemicals like paint and such.
I have it in a sealed bucket for now.
Old Feb 25, 2012 | 07:24 PM
  #25
I used to work at Safety-Kleen, they do all of the used oil recycling for AutoZone, you can pour the coolant in with the waste oil.
If you mix it in a jug half and half with used motor oil they will never know the difference.
Just make sure it is mixed well before you hand it over to the guy.
In other words, shake the jug as you carry it from the parking lot to the store.
Old Feb 25, 2012 | 11:05 PM
  #26
Chris-bob's Avatar
Yup. Always remember. Shaken, not stirred.
Old Feb 26, 2012 | 12:33 PM
  #27
LeakyDisco's Avatar
I just found out the local transfer station for the disposal company here takes antifreeze!
Now I don't have to walk into O'Reilly's all suspicious and shaky like Spike suggested. Whew!
bcbp
Aug 31, 2016 07:37 AM
Nightmel
Jun 1, 2011 12:25 PM
KyShark
May 23, 2011 09:59 AM
jrm123180
May 17, 2010 06:22 PM
JoMar
Dec 11, 2009 08:53 PM
