So WTF Shuttle Valve Electric Failure after new shuttle valves install
Old Feb 2, 2012 | 03:57 PM
bosshogt's Avatar
Default So WTF Shuttle Valve Electric Failure after new shuttle valves install
So I did the option B fix with Joshes writeup. Everything was good for 4 months. I went off roading and really worked the traction control. Got the 3 Amigo on the way home. Ordered the new shuttle valvle repair kit from Lucky8 installed it yesterday. Still have the error. Did notice there was some brake fluid on the old valves. Does that mean new seals are needed? I am over this crappy error. At least this second fix I did not have to bleed the brakes. Is Falcon work in AZ m only option? Do I really have to remove the whole modulator again. F-Me!
1.--Current Faults---->
Active Faults:
114:Shuttle Valve Electric Failure
Logged Faults:
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
Logged Faults:
None
<-END Faults
Old Feb 2, 2012 | 04:58 PM
jafir's Avatar
The only other way I know to get the seals would be to buy the valve assembly at over $500. BUT even if the seals are gushing fluid, the NEW shuttle valve switch should still work without throwing codes, for a while at least.
How's your ground?
Old Feb 2, 2012 | 05:30 PM
ebg18t's Avatar
I thought the Falkon kit replaced the seals?
Old Feb 2, 2012 | 05:37 PM
bosshogt's Avatar
=How's your ground?
That is what I thought. I will check that little bolt on the A/C line holder and then put a temp ground wire to a known good ground. That would be a easy fix. How sweet that would be if it works!
Old Feb 2, 2012 | 06:52 PM
Yes, you need the special o-rings to correct that problem. Falcon Works is the only one making them.
jrmdir
Apr 8, 2013 03:51 PM
NiteTrain
Feb 25, 2013 09:55 AM
aarongregor
Nov 14, 2011 08:31 PM
ruffram
Sep 1, 2011 08:15 PM
lordmorpheus
May 31, 2011 06:48 PM
