Is this Shuttle Valve seal/boot failure?
Old Apr 7, 2013 | 06:44 PM
jrmdir's Avatar
Default Is this Shuttle Valve seal/boot failure?
I did several searches on this but am still confused. Can anyone help me diagnose this and tell me what parts/reparirs are needed? I was assuming the Modulator needed the rewire fix but don't believe these errors point that way.
C - If you're on, thanks again for the help with the scan today!!!
Ron
1.--Current Faults---->
Active Faults:
070:Front Right in valve short to supply
071:Front Right out valve short to supply
072:Front Left in valve short to supply
Logged Faults:
073:Front Left out valve short to supply
074:Rear Right in valve short to supply
076:Rear Left in valve short to supply
077:Rear Left out valve short to supply
<-END Faults
Old Apr 7, 2013 | 06:48 PM
jafir's Avatar
No. That's something else not good. You might check the big plug on the side of the modulator for corrosion or damage wires or something. But I'm just guessing.
Old Apr 8, 2013 | 11:44 AM
jrmdir's Avatar
Thanks Jafir:
I've been reading the diagnosis tips on the RSW site. Looks like I'm in for a bit of wire chasing.
Of course at the bottom of the possible causes list for each code they say something like "or it could be a bad ECU"
Has anyone else ever seen a situation with JUST the in-out valve shorts logged?
Thanks,
Ron
Old Apr 8, 2013 | 12:07 PM
Bkreutz's Avatar
I agree with Jafir on this one, the only commonality for all those codes is the plug or the ECU. I always assume the cheaper option first. As mentioned, check and clean corrosion at both ends of the wiring harness.
Old Apr 8, 2013 | 12:11 PM
jrmdir's Avatar
Thanks Will do this evening.
Or, if it's mice I hope they started at the easy to reach end of the harness
Old Apr 8, 2013 | 03:18 PM
There are 16 reasons for the 3 amigos, sure you can re-wire the module but you will most likely have something else wrong so get a reader or pay to have someone read them, buying the reader is cheaper.
Old Apr 8, 2013 | 03:51 PM
jrmdir's Avatar
Thanks Mike - no argument from me there. My thread stared with the output codes from the ABS Amigo. I was hoping to see just the 114 code becasue the rewiring project is at least a known clean fix.
But, no; I get to end up with codes that are more in the gremlin category.
I'll advise when I learn more.
Ron
04duxlr
Feb 8, 2014 10:05 AM
bosshogt
Feb 2, 2012 06:52 PM
aarongregor
Nov 14, 2011 08:31 PM
lordmorpheus
May 31, 2011 06:48 PM
majrmike
Oct 9, 2007 03:13 PM
