3 Amigos coming on sporadically
It can be shuttle valves, the shttle valve seals or internal electrical faults within the Wabco modulator. It can even be anyone of 4 ABS wheel sensors or worn wheel bearings.
You need a good quality OBD11 reader to isolate the various faults exactly.
Here's some pointers around the Wabco system.
https://www.google.fr/webhp?sourceid...20modification
If you own a D2 you should get an ABS Amigo. I've seen lots on this forum and others for cheap used. They read and clear all your ABS codes. These trucks are very sensitive when it comes to this crap. My D2 lights up in the winter when my brakes squeak.
Definitely don't bother waisting your time or anyone else's until you read the codes. I would bet it's a wheel sensor. They are easy to change. Don't just start throwing money at things.
You are correct sir, I believe there are one or two diagnostic models in the US specifically for reading ABS codes only plus the Britpart Lynx, Nanocom and the Hawkeye. Apart from these I haven't any experience of others.
I get the 3 Amigos fault at lease once every 2 months on my 2001 Disco II.
If I don't have my iCarsoft CR Plus handy to clear the faults I find a very steep hill and then...
- put the Disco in low gear,
- push the "Hill Descent" button on the dash while in Neutral,
- let the truck creep down the hill and let the ABS and shuttle valve do it's job,
- get to the bottom of the hill,
- put truck back into high gear,
- put gear in Park,
- restart the truck and the 3 Amigos are gone for another 2 months.
Adios!
- put gear in Park,
Adios!
- put gear in Park,
Adios!
- put gear in Park,
Adios!
Shryan
06-27-2008 08:33 PM
