3 Amigos coming on sporadically
Old Mar 22, 2016 | 02:11 PM
jamieb's Avatar
I would highly recommend anyone who has not yet done it, just go ahead and give your DISCO the ABS vasectomy. A little snip and stitch and you're done.
Option B is really quite a simple operation once you get the allen wrench socket key.
Old Mar 22, 2016 | 03:04 PM
OffroadFrance's Avatar
It can be shuttle valves, the shttle valve seals or internal electrical faults within the Wabco modulator. It can even be anyone of 4 ABS wheel sensors or worn wheel bearings.
You need a good quality OBD11 reader to isolate the various faults exactly.
Here's some pointers around the Wabco system.
https://www.google.fr/webhp?sourceid...20modification
Old Mar 22, 2016 | 11:09 PM
toofaroffroad's Avatar
If you own a D2 you should get an ABS Amigo. I've seen lots on this forum and others for cheap used. They read and clear all your ABS codes. These trucks are very sensitive when it comes to this crap. My D2 lights up in the winter when my brakes squeak.
Definitely don't bother waisting your time or anyone else's until you read the codes. I would bet it's a wheel sensor. They are easy to change. Don't just start throwing money at things.
Old May 29, 2016 | 09:48 PM
VTsteve's Avatar
Default Three Amigo Fixes
I have been able to get rid of the 3 amigo problems on my 2001 SE7 twice. Once by replacing a bad Hub Assemblies & ABS sensor (expensive) and once by replacing the cheap battery with an Optima Red Top and keeping it on a trickle charger all winter (cheap).
Old May 30, 2016 | 06:29 PM
DiscoBuckeye's Avatar
I have the same issue. Anyone with a scanner near Columbus?
Old May 31, 2016 | 02:31 AM
batard's Avatar
Is it the case that the regular bluetooth-style ODBII code readers won't read ABS stuff? I didn't realize that.
Old May 31, 2016 | 05:36 AM
You are correct sir, I believe there are one or two diagnostic models in the US specifically for reading ABS codes only plus the Britpart Lynx, Nanocom and the Hawkeye. Apart from these I haven't any experience of others.
Old Aug 19, 2016 | 09:20 AM
slink182's Avatar
Hi. I realized the other day that the 3 amigo's have not come on for many months now. Still not sure what caused them to come on sporadically back in February so unfortunately I can't post a solution here. Just wanted to give an update though and not leave the thread hanging.
Best,
Old Sep 8, 2016 | 02:53 PM
JUKE179r's Avatar
I get the 3 Amigos fault at lease once every 2 months on my 2001 Disco II.
If I don't have my iCarsoft CR Plus handy to clear the faults I find a very steep hill and then...
- put the Disco in low gear,
- push the "Hill Descent" button on the dash while in Neutral,
- let the truck creep down the hill and let the ABS and shuttle valve do it's job,
- get to the bottom of the hill,
- put truck back into high gear,
- put gear in Park,
- restart the truck and the 3 Amigos are gone for another 2 months.
Adios!
Old Sep 9, 2016 | 09:47 AM
- put gear in Park,
Adios!
It sounds like one or more ABS sensors are faulty as they also control the TC and hill descent system via the Wabco modulator.
Charlie_V
Aug 27, 2015 04:37 PM
jasonrusso
May 30, 2011 07:42 PM
discomedic4
May 7, 2010 01:57 PM
iplayblues4u@comcast.net
Jan 6, 2010 08:43 AM
Shryan
Jun 27, 2008 08:33 PM
