3 lights in dash
Old Feb 27, 2012 | 09:22 PM
urq's Avatar
urq
Default 3 lights in dash
1st time driving in the rain and I had 3 lights pop on the dash Down Hill, ABS and TC?
Is this the norm?
Turned off the car when I got home then back on and the lights were off?
Old Feb 27, 2012 | 09:35 PM
Do a search for the "3 Amigo's".
Old Feb 27, 2012 | 09:46 PM
urq's Avatar
urq
But wouldn't the 3 Amigo's stay on all the time afterwords?
or until it was cleared by a scan tool?
Mine turned off with the ignition and was off when I restarted the car.
Old Feb 27, 2012 | 09:55 PM
urq's Avatar
urq
OK just did more research and OPTION B is in my future!
Old Feb 28, 2012 | 07:58 AM
matt3502's Avatar
How many miles on your Disco? You should also consider replacing the O ring seals. Take a look at the falcon works kit:
ABS shuttle valve code solution; brake fluid leaks
Old Feb 28, 2012 | 09:02 AM
Don't ever guess what to fix without having the codes read, there are 16 reasons for the lights to come on. In your case, since you only have a soft fault that comes and goes you need to get busy and find/repair the actual problem before the codes lock in.
Do your brakes squeak, are you wheels covered in brake dust, is your brake fluid brown?
Old Feb 28, 2012 | 11:35 AM
urq's Avatar
urq
No squeak, brake fluid is a tad dirty I would say 70% clear I can see through it easily and there might be some dust but I clean the wheels and sprayed it well with water the other day so as far as loose dust No!
Old Feb 29, 2012 | 08:38 AM
Well, until you can get the codes read, when the lights are on, I wouldn't just start making repairs. The trick for you is to find a shop that has a scanner with Rover ABS software in it so you can get the codes read.
booper169
Mar 20, 2019 09:37 PM
gatorgrizz27
Aug 2, 2011 04:11 PM
snowdude
May 23, 2010 10:20 PM
Doral300sc
Feb 6, 2010 03:59 PM
tonyzp007
Jan 26, 2007 11:21 PM
