ABS Amigo code 022 help!
Old Mar 9, 2012 | 11:13 AM
remerson67's Avatar
7th Gear
Default ABS Amigo code 022 help!
The 3 Amigo's have been coming on every day, so I purchased the ABS Amigo and this is the code I get:
-----ABS Amigo Box V1 RSW Solutions LLC Copyright 2010-----
|* The information provided is without warranty of any kind.*|
|* IN NO EVENT SHALL RSW Solutions BE LIABLE FOR ANY LOSS OR*|
|* INJURY OR DAMAGES resulting from or connected to use of *|
|* this Information or Product. YOU HEREBY WAIVE ANY AND ALL*|
|* CLAIMS AGAINST RSW Solutions ARISING OUT OF YOUR USE OF *|
|* THIS INFORMATION OR PRODUCT. *|
1.--Current Faults---->
Active Faults:
022:ECU Gnd or Reference Gnd bad
Logged Faults:
None
<-END Faults
..--Previous Faults--->
Active Faults:
Comms Error
Logged Faults:
Comms Error
<-END Faults
Active Faults:
Comms Error
Logged Faults:
Comms Error
<-END Faults
Thanks in advance.....
Old Mar 9, 2012 | 03:25 PM
What do you think it means???
If you can't figure it out, go back to RSWsolutions and pull up his code page.
Old Mar 10, 2012 | 06:52 PM
remerson67's Avatar
7th Gear
Thanks Disco Mike, I did that and this is what it says.
I do not understand it.....
Old Mar 10, 2012 | 08:45 PM
Here we go -
1. The RAVE has a section on the D2 for Electrical library. In there, you will find a numeric list of every connector on the truck. Click one on, and you get a color pix of location and pin-outs with colors. A couple of these are attached below, you will of course want the whole free set for yourself.
2. I'd check C0500 first, it is a one wire connector on the ABS pump that goes to chassis ground. It is also telling you to look at C0504 pin 12 , a black wire, and see if that reads continuity (very low ohms) or a short to ground. Same for connector C0501 pin 8, which is Black and Slate wire.
3. It wants you to read one connector on a module to the ABS pump conector, to be sure the wire conection on the black/slate wire is good all the way thru. Your meter leads wont be long enough to reach usually, so you have to add wire at one end, like a piece of phone or speaker wire attached to meter lead. Some alligator clip jump leads from a place like RAdio Scrap... er Shack, would help, or an assistant.
File Type: pdf
File Type: pdf
Old Mar 11, 2012 | 06:52 AM
remerson67's Avatar
7th Gear
Thanks Savannah Buzz, I will see what I can do.
Jimbalyia
Nov 9, 2012 01:33 PM
DiscoWest
Oct 1, 2011 08:56 AM
davidlafrance
May 17, 2010 07:05 AM
Princess
Jul 4, 2009 12:24 PM
