Sponsored by: CARiD
022 ECU gnd or Reference gnd bad
Old May 15, 2010 | 02:24 PM
davidlafrance's Avatar
Default 022 ECU gnd or Reference gnd bad
OK, obviously I need to check the SLABS ECU. Can anyone tell me what to do here? Do I need to get an electric meter to test for problems? If so, how do I do it?
Electrical is a short coming of mine.
Old May 15, 2010 | 02:37 PM
Rovin4life's Avatar
let me guess, shuttlevalve failure code.
cause if that is what you got, 99 percent of the time its the modulator causing the issue.
Old May 15, 2010 | 02:49 PM
no, the code is 022 ECU ground fault...I guess I should add that the code came from the Amigo scanner (RSW Solutions)
Old May 15, 2010 | 03:28 PM
Rovin4life's Avatar
you sure its 022. Not 012. thats the shuttle valve failure.
Old May 15, 2010 | 04:55 PM
yes sir
Old May 16, 2010 | 11:47 AM
Rovin4life's Avatar
Does the code come on all the time or go off randomly.
Old May 17, 2010 | 07:05 AM
I traced all of slab ecu ground wires and found continuity with all of them
I ran the amigo scanner again and got the infamous 114 svs failure. So i'll be making that repair today.
I appreciate your reply.
Jimbalyia
Nov 9, 2012 01:33 PM
remerson67
Mar 11, 2012 06:52 AM
DiscoWest
Oct 1, 2011 08:56 AM
EstorilM
Mar 29, 2010 06:04 PM
roverboy
Dec 5, 2008 04:14 PM
