replacing catalytic converter ?
Old Jun 27, 2008 | 11:32 AM
discoken's Avatar
Default replacing catalytic converter ?
Hi I'm looking to replace the catalytic converter on my 99 D1. Any suggestions for brands? I've noticed the two most popular are the magnaflows & catcos. Also what size inlet & outlet do I need 2.25" or 2.5"? Lastly only my drivers side cat is rumbling so can I just replace that one or should I do both at the same time? I have about 115,000 miles. Thanks for you input.
Old Jun 27, 2008 | 11:37 AM
Default RE: replacing catalytic converter ?
First, with your mileage replace both. Second find out and repair what ever killed your cat, be it plugs, wire, coolant leak bad injectors or whatever otherwise the new one may not last long.
Here is one site to shop around on, http://www.completeexhaust.com/produ...roducts_id=184
Old Jun 27, 2008 | 11:41 AM
Landzu's Avatar
On Disco I's Land Rover said to replace the cat's at 96,000 miles in a service book I have.
I waited to last week and 113k but went with a preformance Y-pipe with cat's and new O'2 sensors.
So replace both that way the ECU can read both sides as =.
Old Jun 27, 2008 | 07:19 PM
okdiscoguy's Avatar
Unless you are in CA, Magnaflow makes replacement high flow cats that ran me $325 installed.....
Old Jun 30, 2008 | 01:03 PM
discoken's Avatar
I'm going to order the magnaflow catalytic converters. Do you happen to know the part number that you used? Will this one off of ebay work? http://cgi.ebay.com/ebaymotors/Land-...2em118Q2el1247
Old Jan 19, 2013 | 10:53 AM
markonion7989's Avatar
You can get a better catalytic converter from Magnaflow for less than the dealer. I used, Magnaflow Catalytic Converters at CWIK as they had the best prices and free shipping.
Old Jan 19, 2013 | 11:45 AM
You just replied to a 5 year old thread.
Stay with the more recent ones.
jwmstang
Aug 4, 2022 02:30 PM
JKK
Mar 4, 2006 01:29 AM
arocena409
Feb 13, 2006 01:08 AM
SUMOSINO
Feb 9, 2006 10:04 AM
mgm777
Jul 27, 2005 05:01 AM
