lift kits
Old Jul 26, 2006 | 08:17 PM
Dillon C.'s Avatar
Default lift kits
hey all I am new to land rovers and I am buying a 1999 land rover and was wondering what are some good types of lift kits? I want about a 4' lift kit so if you know were I can get some please e-mail me thanks
Dillon
Old Jul 27, 2006 | 10:32 AM
Default RE: lift kits
Dillion,
What are you planning on doing with your truck when lifted, what size tires are you planning?
You will be better of staying at 3"s, 4's will require you do make drive line changes as well as front radius correctiond, now you are getting into the big money.
Mike
Old Jul 28, 2006 | 03:53 AM
HorizonDesire's Avatar
I am relatively new to the LR scene, too. I have a '99 DII and have just ordered the RoverTym 3 inch kit (www.rovertym.com).
There are a few other kits you can look at, OME (Old Man Emu) makes springs and dampers/shocks(they probably OEM them from somebody), RoverTym makes springs and linkages but uses other dampers (Rancho, Bilstien, Fox, etc). I am sure there are many more, but these seem to be the big players. You can get Koni dampers (mmmmm.... Koni). Most spring makers have various "load" ratings for different uses (heavy duty, standard, etc).
3 inches seems to be the practical limit; above that, you start to have to upgrade drivetrain and the cost skyrockets. Remember the DII has wider fenders and you can fit a larger tire than a DI with the same size lift. 3 inches will allow pretty big tires on a DII.
randywharris
Dec 11, 2011 08:58 AM
OZLandRover
Aug 29, 2011 11:30 PM
agarabaghi
Aug 4, 2010 05:06 PM
evoking
May 11, 2009 09:03 AM
Panama Jack
Nov 21, 2007 08:55 PM
