2" Lift Kits OK?
Old Nov 21, 2007 | 05:01 PM
Panama Jack's Avatar
Default 2" Lift Kits OK?
For reasons of visibility, I would appreciate an additional 2" lift. I don't really want to go the EMU route yet, as the old girl is still a spring chicken at 45,000 miles and there is no discernable sag (yet). What is the general opinion of lift kits of the "Toddco Suspensions" variety? What are the snags, problems etc with installing this sort of gear?
Old Nov 21, 2007 | 05:04 PM
Default RE: 2" Lift Kits OK?
OME or RTE are your only real options. If you go to a 2" body lift on your old suspension you will sway alot because you would then be even more top heavy.
Buy a lift, maybe hold of on the shocks for awhile if you don't want to spend the money now.
Old Nov 21, 2007 | 05:23 PM
Been to the Rovertym website- standard 2" kit (Rovertym coils + OME shocks) approx $600. Are you saying that the Toddco stuff (at $150) won't cut the mustard because of sway? Makes me seaksick... Rather spend the extra $$$?
Old Nov 21, 2007 | 05:40 PM
As much as I like the RTE products, Steve's 2" lift is closer to a 3" and may be too tall for you.
I would suggest going with the OME coils, like I have already mentioned, if money is tight, your shocks don't have that many miles on them and will last for awhile.
Old Nov 21, 2007 | 06:59 PM
ajh's Avatar
ajh
2" isn't going to help much against flood water. Just save up and do it right, then you can have better handling as well as the better look. If the cost of an OME lift is an issue I'd honestly put money in the bank for major service issues, I've seen about $3000 worth in 3 months but that's a bad streak of luck too.
Old Nov 21, 2007 | 08:55 PM
okdiscoguy's Avatar
ORIGINAL: ajh
You are trying to kill your truck, though. I think 3K is cheap for what you are doing....and you are having a dealer do work..
randywharris
Dec 11, 2011 08:58 AM
OZLandRover
Aug 29, 2011 11:30 PM
agarabaghi
Aug 4, 2010 05:06 PM
evoking
May 11, 2009 09:03 AM
Dillon C.
Jul 28, 2006 03:53 AM
