Any experience with P0327
I just found out that the thick black wire got pinched between the mounts when I did my HG. I just spliced it and reconnected it. Was that 2 wires inside that thick black wire? I just saw that minutes ago, that there were 2 wires going to the Knock Sensor from the black wire but it came out from a wire insulation covering. I was wondering also since I replaced the sensor with a new one and nothing happened. I have to cut it again then, since the wire went behind the A/C mount. Can you confirm that 2 wires came from the Manifold? If you can remember. Thanks again
I got a new sensor early this morning and the code came up again, so thinking something triggering that code to show up. Got no codes anymore except this pending code. I need to pass inspection. No engine check anyway.
mine looked terrible, and seemed to have been repaired multiple times. Mybguess is that these are routed terribly and get damaged frequently. Mine's working for now.
