Can you drive with a blown head gasket?
I'm getting a free Land Rover Disco 2, however I have to drive it ~400 miles from NC to Florida. Last time I was with the vehicle I replaced thermostat, flushed coolant, added coolant, and bled all the air out.
The waterfall sound behind the dash went away however I didn't get a chance to drive it around to make sure it didn't overheat at all. I got a family member to drive the vehicle the other day (before I go pick it up) to see if its in good running order, they said they drove it around 30 miles, no overheating, and everything runs good.
However if for whatever reason the headgasket is gone and the waterfall sound comes back on my roadtrip down to FL, can I keep driving on it if I stay around 55mph on the highway and make sure coolant stays topped up? No I haven't done the chemical test. This is just worst case scenario.
To answer your question yes depends on the severity of it.
I would not risk it with out a ultra gauge to monitor real temps the idiot gauge will not give you enough time to pull off to the shoulder... if you have some tools and a few hundred bucks you could just make the repair in Flordia before you drive home. Then your set also be careful with the drive shaft especially since its been sitting. .
If planning on HG job anyway,,,, carry a container of stopz leakz product, like KSeal. May slow down leak for a while if needed. Also use a scanner or Ultra Gauge to keep an Eagle eye on the coolant temp. Carry water, so you can top off as needed between exits if stuck.
Also keep an eye on the coolant cap and the oil dipstick for signs of liquid crossbreeding.
Randy P
09-27-2007 08:27 AM
