D1 Manual Transmission: strange behavior
Old Oct 27, 2009 | 08:21 AM
apcollin's Avatar
Default D1 Manual Transmission: strange behavior
I have a 96 disco with a 5-speed manual, and I'm having trouble diagnosing my current problem...
The clutch is acting less "responsive" than usual (not slipping)
To shift I have to apply throttle, put in clutch, wait a second for the RPM's to drop (that's the weird part), then shift.
I was thinking it may be the syncromesh gears (which I'm guessing are internal) but yesterday the clutch was "stuck" half-engaged for a few seconds until I pumped it once quickly so now I'm thinking maybe it's a clutch-engagement issue.
Any thoughts?
Old Oct 27, 2009 | 08:51 AM
Scott R's Avatar
Sounds like a clutch master or slave starting to go. Replace them in pairs if that's the case.
Old Oct 27, 2009 | 11:25 AM
antichrist's Avatar
Yup, sounds like the MC or SC. And yes to replacing both (unless one has just recently been replaced). I'd also do the flex line.
Old Oct 27, 2009 | 02:52 PM
That tranny is also know for syncro issues and in some cases, shift for problems.
Old Oct 27, 2009 | 07:08 PM
apcollin's Avatar
Yeah it hasn't been the best manual transmission I've used, that's for sure.
I'll consult RAVE per bleeding the system...
Old Oct 28, 2009 | 07:10 AM
antichrist's Avatar
When it's the syncros you don't need to pump the clutch.
SingleSpd
Sep 30, 2013 12:29 PM
ejag42@mac.com
Apr 3, 2013 11:59 PM
SHAGUAR
Feb 14, 2013 09:20 AM
green_
Dec 15, 2012 11:02 AM
WaltNYC
Apr 5, 2011 06:01 PM
