Strange SLS Behavior
Old Sep 30, 2013 | 11:51 AM
SingleSpd's Avatar
Default Strange SLS Behavior
I have a 99 DII with 160k mi.
The rear air suspension has been acting up lately. I searched the forums, but haven't found any threads describing the same problem.
First, I'll say that I can park the Disco for days with the suspension aired up, and it will not leak down. I have sprayed soap all over the air lines and compressor, all is good.
However, when I have some weight in the back, such as 2 passengers, camping gear and bikes, after a couple of hours driving the suspension will go down and the compressor will not come back on to air it up (yes, with the hood and all 5 doors shut)
Also, sometimes, when I park the truck, as soon as I get out and shut the door, the compressor will suddenly let all of the air out. I can hear it coming from the exhaust inside the rear fender. If I start the truck back up, and shut the door, it will air back up and keep all day.
Is there a solenoid or sensor that may be going bad?
The compressor is so expensive, if I have to replace it, I might as well go with the Terra Firma 2" MD kit and get rid of this headache all together.
Old Sep 30, 2013 | 12:29 PM
drowssap's Avatar
yes, there are solenoid's in the same box as the compressor, you best bet is to email DM he knows quite a bit about the SLS and has been helping people save there systems rather than canalize it with coil springs
ejag42@mac.com
Apr 3, 2013 11:59 PM
SHAGUAR
Feb 14, 2013 09:20 AM
green_
Dec 15, 2012 11:02 AM
WaltNYC
Apr 5, 2011 06:01 PM
apcollin
Oct 28, 2009 07:10 AM
