strange headlight behavior
Old Apr 5, 2011 | 12:44 PM
WaltNYC's Avatar
Default strange headlight behavior
- When 'parking' lights are on, driver's side looks proper, passenger not illuminated
- When low beams are on, driver's side looks quite dim (but brighter than parking) while passenger side looks normal.
- When brights are selected, driver's side is incrementally brighter, but far from normal. Passenger side is normal (for high beam).
I just replaced the bulbs hoping that would do it but alas, it did not fix the problem.
I've read that the switch can go bad and I figure that is the culprit, but would love to get the collective input of the esteemed members of this message board.
Old Apr 5, 2011 | 02:02 PM
XCELLER8's Avatar
before you spend money......remove the 3-prong connectors @ the bulbs and check/ clean them......also "wiggle" them while the lights are on to see if any of this makes a difference....they arent always sealed all that well and prone to corrosion...it's worth a try
Old Apr 5, 2011 | 06:01 PM
Danny Lee 97 Disco's Avatar
I agree, remove all connectors and clean them good first. I was just reading theRAVE yesterday and noticed that they call for Petroleum Jelly to be used on the electrical connections to help keep water out. I guess Vaseline works in a lot of unusual applications.
I recently had to replace my headlight switch due to a problem where the instrument cluster and tail lights would go off at tke headlight on position (last click). My switch was shot. Got a good one from Will Tillery for $65 bucks shipped.
SingleSpd
Sep 30, 2013 12:29 PM
ejag42@mac.com
Apr 3, 2013 11:59 PM
SHAGUAR
Feb 14, 2013 09:20 AM
green_
Dec 15, 2012 11:02 AM
apcollin
Oct 28, 2009 07:10 AM
