Dash Brake Light Stays on - just cold?
Old 01-07-2010, 11:13 PM
Rover_Hokie's Avatar
Default Dash Brake Light Stays on - just cold?
Released the hand brake on my D2, but light in dash stays on. I do not feel any braking when I move it, and I drove it a little. So, where is the switch that turns the light off/on? Can I adjust or clean it, or is it just cold?
Old 01-07-2010, 11:40 PM
NiteTrain's Avatar
check brake fluid level, use only DOT4 only if low.
Old 01-08-2010, 08:00 AM
lipadj46's Avatar
The switch is in the cap to your brake fluid reservoir. It is designed to turn on when your fluid is low due to your brake pads being worn out.
Old 01-08-2010, 08:41 AM
XCELLER8's Avatar
the light serves 2 functions...........1. to let you know when there is insufficient fluid in the reservoir, and 2. to let you know that the brake lever has been applied. and therefore 2 "switches" one at the reservoir and the other I believe is attached to the handle hidden by the center console. so...yes by all means check your brk fluid, make sure that the handle is all the way off, and then maybe the cable hasn't come all the way back to the off position...and that means getting under the truck and checking out the cable situation
Old 01-08-2010, 08:44 AM
You have to remove part of the console to check/adjust the e-brake and switch.
But as already mentioned, check your brake fluid level, you brake pads may be getting thin and then the level starts to drop.
Old 01-08-2010, 10:49 PM
Thanks for all the help. I will check the fluid, the brake pads have about 35K on them, so may be about that time as well.
dcox1974
12-16-2016 08:03 PM
zx14
10-17-2014 09:10 AM
Savannah Buzz
02-10-2014 10:52 AM
dankdistrict
01-28-2010 11:10 PM
dillhole
08-07-2008 04:10 PM
Quick Reply: Dash Brake Light Stays on - just cold?
