Dis II 2003 V8, Air con and heating issue
Old Jun 18, 2013 | 12:08 PM
  #31
russburcham's Avatar
R32- Would you mind taking some pix of the additional fan you installed--Also, some more detail on how you wired it?
Thanks so much!!
Old Jun 18, 2013 | 09:27 PM
  #32
R32's Avatar
R32
Thanks so much!!
Sure, was planning to post this pix anyway..
Old Jun 18, 2013 | 09:28 PM
  #33
R32's Avatar
R32
Today the temp did get to 200F and 202F at time but not more as there was quite a traffic this morning..
Old Jun 19, 2013 | 10:18 PM
  #34
R32's Avatar
R32
last night was driving home did not turn A/C on temp went to 206F and then turn on A/C temp went down to 198F-200F
Old Jun 20, 2013 | 01:01 AM
  #35
Because you increased the air flow over the radiator.... so if radiator is a problem to start with that could be expected. The 180F stat should get you performance like this, a member shot this on a trip into the desert.
Attached Thumbnails Dis II 2003 V8, Air con and heating issue-bc8afb25-b563-4331-bdd7-c77d9c7f7685-8721-00000924dc11272f_zps3eba1104.jpg
Old Jun 20, 2013 | 09:26 PM
  #36
R32's Avatar
R32
Thanks, that's is something I'm hoping i could get for the temp. But again where i am is much hotter and known for nightmare traffic.
Today the temp was 206-207F at max, highest so far since installing the additional fan, friday morning traffic too...
Roll on weekend...
Old Jun 23, 2013 | 10:19 PM
  #37
R32's Avatar
R32
Thanks so much!!
Here's the pix, unfortunately i did not took the pix while installing this, and as i have also install headlight guards it a bit difficult to take the grill out, sorry for this!
What missing from the pix here are 8" universal fan and 30 amp fuse and housing
Wiring one to battery one to ground,
Fuse housing and relay tired up next to existing fan as there are space available.
New fan on the right
This is how I tired the new fan to the existing air con condenser frame
Hope this help! let me know if you have any questions
Old Jun 23, 2013 | 10:33 PM
  #38
R32's Avatar
R32
Weekend checked the radiator, seem to be OK with temp even all over from top to bottom so next installed a fan (used fan PGG000080 with better clutch and had 11 blade more than the existing one which had only 9 blade) also installed front headlight/rear guard, unfortunately the lower rear light can not be installed as it had rear reversing sensor installed next to it so not enough room for this, I took her out for a sunday morning run, very happy...
Monday morning traffic, the temp was more stable at 195-197F at idel and 190-193F at normal speed with max temp at 200F at 10 mins stop at traffic light..180F Tsat is on the way in the post...any other way i could do to get the temp down or is this seem about right??
Old Jul 3, 2013 | 09:59 PM
  #39
R32's Avatar
R32
Couple of weeks on..yesterday the temp was 200F at Idle where as 195-197F before as well as TC/handbrakes/ABS lights where on but still drive normal. Got home and open the bonnet and found splash of coolant were on top of CRUISE CONTROL VACUUM PUMP ACTUATOR and wire below as well as some on the edge of the reservoir where the excess pipe is. Re start the engine again and the TC/handbrake abs light were gone.
Is there too much pressure in the coolant, need another look at the radiator?
Old Jul 5, 2013 | 01:47 AM
  #40
R32's Avatar
R32
Found out that the coolant reservoir is leaking at the seamed near excess pipes, so using epoxy to fixed this for the time being also water pump is really in need of replacing too so just bough one from ebay...hope to have it soon (along with the 180F Tsat)
