Discovery II Electrical Library & Diagrams
Old 06-30-2012, 02:02 PM
Enrique5's Avatar
LOL yea right! was funny. He kind of felt bad when I pointed it out. We finally seem to find the culprit. The crank sensor connector would not pass continuity. Further following the wire reveals a tear. I'm going to repair it now.
Old 06-30-2012, 02:22 PM
See attached for pages on the sensor and signal output from same. If removing, be dang sure every little spacer and nut goes back in same sequence. Tolerance is about a gnat's eyelash.
Attached Thumbnails Discovery II Electrical Library & Diagrams-ckp-sensor-internal.jpg
File Type: pdf
Old 07-01-2012, 01:52 PM
Enrique5's Avatar
Smile
Wow Thanks, good info. I finished and the truck ran great. I still got some codes showing on the diagnostic. And the right hand O2 harness needs repairing. One of the faults is that sensor. That sensor harness melted against the manifold.
Right now, I'm just very happy to see this truck run. As far as I know this truck has not run in a year.
Here are the codes i got now:
P1590 ABS rough road signal circuit malfunction
P0150 O2 sensor circuit malfunction (bank 2, sensor 1)
P0174 System too lean (bank 2)
P1884
P2903
P0003 Fuel Volume Regulator Control Circuit Low
Joemamma1954
04-08-2015 10:10 PM
dw00594
08-30-2014 04:31 PM
wolfgang528
Defender
12-28-2010 04:25 PM
Fairview
12-09-2010 05:12 AM
moocowman
01-03-2010 05:33 AM
Quick Reply: Discovery II Electrical Library & Diagrams
