question/ repair for oil leak
Old Jan 24, 2012 | 02:26 PM
Ad!'s Avatar
Ad!
Default question/ repair for oil leak
So i went out to take a last look at my truck before ordering parts to see if i could find any other parts that might need replacing. while out there i crawled under and noted that theres a screw missing under my engine but im not sure if its something i should be worried about ( pic below)
second, while under there a noted what looked like a oil leak under the exhaust manifold. i need help identifying a possible gasket i could replace in that area, please take a look at the pics below. one picture was taking under the car and one was taken from above.
last i took some pics of my left side rocker gasket just to see if anyone can confirm if it needs to be replaced or not. i think it should be, just looking for other opinions. id really appreciate any help i can get guys, thanks.
Old Jan 24, 2012 | 02:29 PM
Ad!'s Avatar
Ad!
also when the engine is open what can i use to clean all of the gunk off? plastic spatula and brake cleaner? after cleaning should i coat with oil?
Old Jan 24, 2012 | 02:39 PM
Many owners find that the valve cover gaskets loosen, and need to be snugged up every oil change. They leak down below. Bolts are 8mm 12 point, skinny socket (3/8 necked down, or 1/4 inch drive). You should wash off the engine before work to locate leaks (power wash at car wash, degreaser, etc.). If you will be removing the oil pan, it can be washed out. Yes, good idea to spay some oil back on inside before assembly (squirt bottle), but engine will do a pretty good job of spashing oil around when re-filled. You can use oil flush before draing the oil (follow instructions on can), but that won't get the big stuff in just a few minuutes of use.
Old Jan 24, 2012 | 02:57 PM
Ad!'s Avatar
Ad!
which one is the valve cover? do you know where my leak could possibly be coming from under the exhaust manifold?
Old Jan 24, 2012 | 05:06 PM
Ad!'s Avatar
Ad!
can anyone list the tools that ill need for a head gasket job please?
Old Jan 24, 2012 | 06:16 PM
thebloody's Avatar
I have never changed the head gasket on a Land Rover but I have done it on a Jetta diesel. So a torque wrench is the most important tool, also be very careful when taking off and putting back on the cylinder head. The reason is that if you screw up the order of which bolt you loosen first, second ect... you can warp your cylinder head. Also remember when loosing the bolts to do is a 1/8 turn on each bolt (in order) and make sure to use new head bolts when putting the cylinder head back on because the bolts stretch overtime.
Edit: Also I am pretty sure the bolts are spline.
Here is a link for some more info:
Rovers North - Technical Tips Installing New Head Gaskets Range Rover | Discovery Parts Defender
Old Jan 24, 2012 | 07:06 PM
re: which one is the valve cover?
re: can anyone list the tools that ill need for a head gasket job please?
If you have to ask the first question, are we ready for the second (lol)?
Perhaps I did not make myself understood. Valve covers frequently leak oil, dripping down on and around the exhaust manifolds. The covers leak oil because the the bolts holding the gaskets loosen, many owners snug up the 8mm 12 point bolts, four per valve cover, evey oil change.
You'll want to download and study the sections of the RAVE factory shop manual set that covers the HG work. And the bolts stretch on installation, should never be re-used. The RAVE includes the specs for warpage,and angles to measure, .002 inch, your printer paper is like .0038 - not much. A kit of parts is like $300, with bolts, and machine shop work to plane the heads is about $200.
But what other indicators do you have for a head gasket job being required?
Old Jan 25, 2012 | 02:54 PM
Ad!'s Avatar
Ad!
I'm looking to do my head gasket / other gaskets because my trucks misfiring on the entire left bank, and as you can see the valve cover seems to be leaking on the left
Old Jan 25, 2012 | 03:05 PM
Most owners here are doing HG because of coolant leaks and over heating. Misfires, even multiple ones, are frequently plugs and wires and sometimes coils. Of course the valve covers have their own gaskets. But armed with the RAVE shop manual you'll have an easy time of it.
Old Jan 25, 2012 | 03:16 PM
Ad!'s Avatar
Ad!
ive change plugs and wires already. havent changed coils because i dont think that my coils are both failing on only the left side. do you think that leak is unrelated to my misfires?
TennesseeRover
Mar 19, 2014 08:16 AM
zee
Jun 20, 2012 07:50 PM
Boats121
Sep 20, 2010 06:28 PM
humroot
Jul 3, 2010 10:29 PM
