Heigh lift jack
I use a hi lift from time to time i think its the 48"version. The plastic side rails are not strong enough to support the truck how ever if you remove them the you can jack the truck up. Its a bit of work but it can be done. I've jacked up my rear end by removing the plastic, opening the rear door so the jack doesn't scratch the outside of the door and it works pretty well. Remember to always chock your tires.
Hi-Lift Lift-Mate (LM-100)
Hi-lift jacks are dangerous enough (about 40 years experience with them) without taking chances with a knock-off. If you do get one, get a Hi-Lift.
I off-road several times a month in the summer and have seen people almost had their head taken off with a Hi Jack handle. They are pretty dangerous b/c they are tippy and when weighted the handle can spring up. I could see using it has a winch if needed but I would recommend a bottle jack or the X-Jack to raise a vehicle.
My Smittybuilt came in today, looks to be pretty nice and well constructed. Yes, they are dangerous at times if you use them incorrectly, but with a little patience and caution they are pretty much fine. The Smittybuilt looks plenty strong, but I've yet to use it. I'll probably give it a test this weekend.
