If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
I am looking at a couple of used, very low mileage (50k) Discoverys. One is an 2003 and the other 2 are 2004 models. Other than the colors does not seem to be much difference in condition or price. Can anybody tell me if there were any significant upgrades or reliabilty issues that would set these years apart?
Some 03 comes with oil pump problems... Need to watch out on that
__________________
03 disco:Roof rack, 4 Hellas 4500, 100 watt's HID head light. Center Diff Lock and ARB Lockers front and rear with ARB compresor, Warn 12lbs winch, 35/12.5/R-16 PITBULL's ROCKERS. 5" lift Kit from rovertym, front radius arms, shock adapters from rovertym, mantec snorkel, ranchos 9000, Toms Wood front drive shaft And Toms Wood rear drive shaft... sway bars remove front and rear, Stainles steel brake lines, abs lines extended, rear watt linkage from rovertym, High lift and jerry can !
Need Parts? paulgrant@mac.com, or 203-770-1699 willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
