Key won''t come out of the ignition unless I disconnect the battery ??
Old 12-19-2009, 01:23 PM
josemex's Avatar
Unhappy Key won''t come out of the ignition unless I disconnect the battery ??
I replaced my brake switch so I can move out of park but now
Key won''t come out of the ignition unless I disconnect the battery any Ideas??
Old 12-19-2009, 02:26 PM
meltdowndave's Avatar
The ignition isn't sensing that the tranny is in park or neutral.
Is the brake switch installed correctly? Transmission in park (silly question, but eliminating the obvious)? Have you been having flashing M and S lamps (XYZ/neutral safety switch problem)?
Old 12-19-2009, 09:23 PM
First things first, we need to know what year the truck is.
Second, pop the trim piece off of the top of the gear shift ****, tighten the nut in there a few turns.
The key should just come right out then.
The transmission is not going all the way into park and not releasing the key from the ignition. (DI)
If it is a DII it may be that or a bad switch on the transmission, like the XYZ switch.
Tighten that nut first.
Old 12-20-2009, 01:35 AM
josemex's Avatar
sorry 96 D1 170000 I'm going to try that
Old 12-20-2009, 12:05 PM
Let us know how it turns out.
Old 12-20-2009, 06:48 PM
josemex's Avatar
Do you know what size is that knot, I tried with a 21 but ir's kind of loose, i already tight it up as much as I couls with the 21 but it seems is not the right size socket and a 20 mm would not go in. When I push the pin in the kew will come out but the chime keeps sounding and the shifter would not go to park, so until I find a fix I'l just leave the key in, beacuse it's a pain to disconect the battery every time I leave the truck. The key turns almost to the zero position do you guys think that will drain the battery???
Old 12-20-2009, 08:38 PM
That nut is in no way a 21mm, 12mm maybe but not a 21mm.
I do not know what size that nut is, try a SAE size and see if that fits.
Melissa Folta Scath
01-24-2013 01:07 PM
pottzie
07-25-2012 09:24 PM
sfxgamer
12-24-2010 12:58 PM
hwild77
03-25-2010 12:16 PM
dustondo
04-17-2008 09:28 AM
Quick Reply: Key won''t come out of the ignition unless I disconnect the battery ??
