Battery Dead, key sometimes won't come out,
Old Dec 22, 2010 | 07:40 PM
sfxgamer's Avatar
Default Battery Dead, key sometimes won't come out,
My transmission is donezo as of the other day. I put it in park but it still seems to be in neutral. I tried starting it up but it wont start and i have to turn the key a bunch of times to get it out. It started up fine the other day I'm wondering what I have to do to fix this. I just need the engine to run as I'm selling the engine.
Old Dec 22, 2010 | 07:44 PM
Your transmission is not toast.
Pop the trim piece off of the gear shift **** and tighten the nut.
Now all is well once more.
The key will come out and you can put it in park, reverse...it will be fixed.
Then send me $20.
Old Dec 23, 2010 | 08:02 AM
okdiscoguy's Avatar
if you put it in park but it seems to be in neutral, I would have someone put it in gear and hold the brake while you look under the truck.
You either have a blown diff (or axle or cv), or a broken driveshaft.
Old Dec 24, 2010 | 12:58 PM
Danny Lee 97 Disco's Avatar
It sounds like the game should not play with Land Rovers.
jgeorge
May 19, 2012 06:24 AM
grandkodiak
Apr 2, 2011 10:56 AM
josemex
Dec 20, 2009 08:38 PM
