Light up like a Christmas Tree!
Old Apr 22, 2009 | 11:16 AM
Wahoo25's Avatar
Default Light up like a Christmas Tree!
Hi all,
I purchased my '99 Disco II about 2 years ago with 117,000 miles on it. I've been adamant to keep up with all of the regular maintenance, replaced tires, done some minor cosmetic work, etc. So far *knock on wood* we've only had two major repairs on it: replacing a blown head gasket and removing & replacing a broken water pump. Now approaching 140,000, I've started noticing an electric "humming" noise when slowing down to stop (usually between 5-10 mph). Could there be something wrong with the braking system?
Also, after having taken it on 2 lengthy highway trips recently, I've noticed that occasionally when I apply the brakes, all of the yellow warning lights on the dashboard will light up (the ABS warning light, the Traction Control, and the Downward Slope Assistance light) along with a "ding". We've had the brakes checked by one of our local mechanics that has worked with the truck in the past. Is this something that I should suck up and take to the dealership and endure the beating??
Thanks!
Natalie
Old Apr 22, 2009 | 11:28 AM
AK Rover's Avatar
Search for the 3 Amigos. You'll find the answer to your questions. This has been covered 1000 times
Old Apr 22, 2009 | 11:49 AM
NiteTrain's Avatar
I thought with 3 amigos the lights came on and stayed on..so it can be intermittent when braking?
Old Apr 22, 2009 | 12:00 PM
Natalie,
If the lights come on once in awhile, I would suggest you do a full, 3 pint brake flush. Also, are your brakes squeaking?
Old May 21, 2009 | 11:27 PM
Wahoo25's Avatar
Wow, I had no idea I was in such great company with the "three amigos" problem! After reading through the 1,000s of posts on this topic, it seems this is a very common problem with the D2s (with several possible causes!) and it got me wondering: how come no assistance/recall from LR!?
Anyways, thanks for all the tips! We cleaned off the ABS sensors and inspected all the wiring (seemed to be a good place to start) and put those amigos to rest! Until a week ago at least...now this will become my Memorial Day Weekend project when I can get out the diagnostic stuff and really try to crack what's going on. I'll let ya'll know if we come across anything interesting/helpful/confusing!
Thanks again!
Old May 22, 2009 | 08:04 AM
There is little or nothing you can do to trouble shoot the 3 Amigos.
You might want to PM me your tele number so I can walk you thru what is coming up.
hilltoppersx
ROAMING WITH FRIENDS
Dec 4, 2011 09:09 PM
sloppyjoe
Nov 28, 2008 04:20 PM
autooracle
Feb 9, 2007 05:48 AM
autooracle
Feb 8, 2007 09:43 AM
Locust Inn
Jun 25, 2005 03:13 PM
