Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-25-2012, 01:59 PM
MrFlea1's Avatar
Member
Default Oil Pressure light on
just finished the Timing gear rplacement and the oil pump grears. Now all back together and the oil light is on ............... what could be the problem SImple or redo?? Need to check oil pressure but not sure where to do that. Is there an oil pressure sending unit?? or do I need to us the oil cooler lin connections. Thanks
Old 01-25-2012, 02:40 PM
Senior Member
Oil pressure switch is what turns on the light, on passenger side of engine near front. Remove switch and put in temporary oil PSI gauge. Wire to sensor could be grounded and that will also keep light on. See attached pix from RAVE electrical library and the world's cleanest Disco - it is C0187. Oil gauge should read over 10 PSI idle hot, and 50 PSI at 2000 hot.
__________________
Old 01-25-2012, 08:19 PM
MrFlea1's Avatar
Member
Quote:
Thanks I will do this the 1st thing in the AM. I bought an oil pressue guage and may consider installing it instead of the idiot light. Would hate to have to redo the pump installation BUT if needed I at least can do it faster the second time....... Damn is that photo of that motor NICE.
Old 01-25-2012, 08:43 PM
Senior Member
If your switch was not hooked up, and wire was sitting just right, and touching a ground, light would be on. Also, if wiring harness got skint, light could stay on. You can meter the switch to ground, wire off, with an ohm meter, short = switch closed. Be careful under there with rotating parts. Having your fingers make a trip around the serpantine belt will spoil your day.
__________________
Old 01-25-2012, 09:21 PM
94svt50's Avatar
Senior Member
did you use a new o ring on the oil pickup? did you put any lube on the new gears?
__________________
'03 HSE7 112k driveshaft/headgasket/water pump/oil pump/all fluids akebone pads and new rotors and I have almost had it a year
'02 pathfinder 160k
'89 yota 4x4 251k
Old 01-25-2012, 09:22 PM
Philip Lawrence
Send a message via Skype™ to Spike555
Did you prime the oil pump with grease first?
If you just install the pump and do not prime it it will not pump oil.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 01-25-2012, 09:40 PM
94svt50's Avatar
Senior Member
but, if you pack that thing solid with gease it also will not work. There was some one on here that had to take theirs back apart becase they had packed it so full of vasoline it would not pump it out. I just coated mine with a thin coating of grease and as much gear oil as I could get in it and primed the system by cranking with fuel pump fuse pulled.
__________________
'02 pathfinder 160k
'89 yota 4x4 251k
Old 01-25-2012, 09:43 PM
Philip Lawrence
Quote:
Yes, thank you, that is what I meant but did not clarify.
Thank you for setting the record straight.
__________________
www.marshill.org
www.20liters.org
Old 01-25-2012, 10:16 PM
Senior Member
Here's what I've done and it worked great. Pull the threaded plug on the the front cover which is located just below the oil pressure sending unit. Take a small hand oil pump and insert the filler neck in the now open front cover hole and fill up the oil pump with oil until it over flows out the open hole. You must make sure your oil sump has oil in it prior to doing this so the oil your pumping in just doesn't backflow from the pump into the oil sump.
You also will not get oil pressure if you attempt verify pressure before start up by pulling your ignition fuse. The starter doesn't spin the engine fast enough to build any readable gauge pressure.
__________________
2004 Vienna Green SE Discovery 80K, Aftermarket Oil Pressure and Temp gauge warning system, Head gaskets replaced 09'. 2011' Turner Reman Block, Heads Overhauld, Crank machined, New Bearings, Front Cover, Pistion Rings, New Cam/lifters, Timing set,All new Hoses, Radiator/Thermo and much more.
2003 Oslo Blue SE7 Discovery 60K, Aftermarket Oil Pressure and Temp warning system, New Radiator, Thermostat
Old 01-25-2012, 10:18 PM
94svt50's Avatar
Senior Member
Happy to help you clarify any time you need it.
__________________
'02 pathfinder 160k
'89 yota 4x4 251k
Tags
2000, 2007, discovery, idle, ii, land, light, oil, pressure, pump, rover, savana, sender, sending, switch, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
