Rear Drive Shaft Flex Coupling Replacement Question
Old May 31, 2011 | 03:14 PM
hunter's Avatar
Default Rear Drive Shaft Flex Coupling Replacement Question
Will be replacing this shortly. Do I need to lube the center ring that comes with the coupling and bolts, or does it go on as is? Rave doesn't specify.
Thanks in advance.
Dave
Old May 31, 2011 | 05:11 PM
jeffh's Avatar
certainly hope not.. as I did not when I did mine a few months back... My Mechanic friend who lets me do my work at his rover shop said that it was not needed, but I am certain that someone will say that you should. I did not no worries.
Old May 31, 2011 | 05:46 PM
hunter's Avatar
great, thank you. One more question. Did you need to use the LR driveshaft 9/16 socket tool, or could you is a standard 9/16 socket with an extender?
never mind. was just under the truck and realized it is a 3/4" bolt and nut.
DiscoJon
Jul 14, 2019 01:51 PM
jenniemcl
Jan 15, 2011 07:10 AM
Spike555
Jun 2, 2009 11:19 PM
wcryer
Jun 5, 2008 12:08 AM
fasterdammit
May 9, 2007 09:26 AM
