Spark plug wire diagram?
RE: Spark plug wire diagram?
http://www.roverparts.com/TechTips/b...onnections.cfm
*NOTE* As stated on the picture, this diagram is viewed from the rear of the truck, so you need to reverse it if you're looking into the engine bay from the front.
The best place and price for the Magnecor's is Cerrone's.
I do not know if all of Bosch car parts are made in Germany or not.
But I do know this, Bosch dishwashers and washing machines are made by Seimens. Same assembly line different name on thje door. A friend of mine is a engineer at Seimens. She will not buy a Bosch or Seimens appliance.
I knew when I was left stranded on I-25 with a flashing check engine light and a horrible misfire. Use the Magnecors! Also, I did NOT remove the intake manifold to change the plug wires. I removed the secondary air pipe running over the rear of the engine and then layed over the top with a long flat-tip screwdriver prying off the old wires. I used this diagram to snap the new 8mm wires into place.
Cheers,
Pete
[IMG]local://upfiles/10333/1E2A258B2AE7448CAF39335A0D7E61B9.jpg[/IMG]
Cheers,
Pete
I do not know if all of Bosch parts are made in Germany or not.
