Support roller seems to be sticking...
Old 09-29-2007, 03:44 PM
jwfuller's Avatar
Default Support roller seems to be sticking...
Another mechanical question...
How much should the support roller below the belttensioner spin? If I try to spin the roller, it just stays as far as my finger moves it. The other belt support roller on the drivers side continues to spin. My question I suppose is, does the roller have some bearings in it that are going out? Thanks.
Old 09-29-2007, 07:27 PM
Landzu's Avatar
Default RE: Support roller seems to be sticking...
It is going out replace it before it cost you a belt,
and strands you when it locks up.
Old 09-29-2007, 08:13 PM
Also consider replacing both of your idler pulleys, they are also known to fail and are usually replace at the same time.
LRD2&ME
05-23-2021 07:57 PM
bcolins
03-22-2012 05:47 PM
malibutj
05-06-2011 10:57 PM
montez27
Engine & Internal
08-26-2010 12:32 PM
slave600
10-11-2008 08:51 PM
Quick Reply: Support roller seems to be sticking...
