Ultra-gauge question
Old May 8, 2012 | 01:26 PM
sorbet35's Avatar
Default Ultra-gauge question
Hello all,I just got my ultra gauge and I cant figure out how to display the battery volts and out side temp,also i think the paperwork for that $9.00 rebate is crazy.........THANKS
Old May 8, 2012 | 01:46 PM
ODIN's Avatar
3rd Gear
I couldn't get mine to display the battery volts either. I was hoping to be able to monitor that but I don't think it's one of those options that work on a D2. I have mine displaying the intake temp on one of the screens and I think that's about as good as it gets. I normally just hit the button by the heater control when I want to check outside temp. Yeah, they definitely try to drive you nuts with the rebate thing so you'll just quit and they can keep your $9!
Old May 8, 2012 | 02:23 PM
sorbet35's Avatar
Thanks for the reply,I must say Im a tad unhappy with this thing.Seems like its only good for coolant temp and code reading.I know it could not read oil psi(shame) but i at least hoping for volts.
Old May 8, 2012 | 03:17 PM
Eaglerover22's Avatar
You can get a volt meter from Walmart that plugs into your cigarette lighter. It's something like $15-20.
Old May 8, 2012 | 04:10 PM
Yep, it can only show what is sent to the OBDII as data, even though the OBDII has a +12 volt power lead that runs the Ultra Guage... (Ultra Guage should make an upgrade)
My scanner won't show volts on the Disco, but does on the SWMBO Kia ('06).
Here's the plug in volt tester https://landroverforums.com/forum/ge...hlight=voltage
As for Oil PSI or temp, those don't come out the OBDII, so no joy on that.
Old May 8, 2012 | 04:47 PM
sorbet35's Avatar
That plug in volt tester is the way to go.....Thanks
Old May 8, 2012 | 07:58 PM
It can only show the info it is given, the Rover does not have a volt meter or oil pressure gauge on the dash so the ECU does not get that info so the Ultra Gauge cant show it.
Old May 8, 2012 | 08:07 PM
sorbet35's Avatar
But is does have a low oil press and volt warning lights so i assumed that the ultra gauge would of tapped into those sending units.
Old May 8, 2012 | 08:11 PM
You said the magic word - warning lights - these are triggered by a switch (oil pressure) and the alternator voltage being at a certain level. No "sensor" like an engine coolant sensor or an oxygen sensor or such.
Old May 8, 2012 | 08:13 PM
But those are not sending units, they are simply on-off switches.
Oil PSI drops below "X" and it closes the circuit and the light comes on.
Battery volts drops below "X" and it closes the circuit and the light comes on.
It is that simple, unplug your oil PSI sending unit and touch the connector to bare metal, the light will come on if the engine is running.
If there was a oil gauge on the dash then the ECU would actually get data on oil PSI and it could be shown on the U-G.
